We're planning to fit an ikea kitchen ourselves - finger crossed! I have a few questions and was hoping to get some thoughts/advice from the forum.
1. Ikea has advised that all their base units are designed to be wall-hang and the legs are not designed to support the weight of the units. However, part of our kitchen walls are stud walls with no plywood backing so I'm not sure if the plasterboard can support the weight of the units. Could anyone advise whether base units have to be hanged on the wall or can we be cheeky to just leave them supported by the legs? If they have to be wall hang, is it good idea to use those special plasterboard fittings or should I consider apply a plywood in the back - the stud walls are still being built so if needed then this can be done.
2. Wall units - we are having some wall unites and a cooker wood on the stud walls. My carpenter thinks that it's fine to hang them use the special plasterboard fittings. I have heard stories that cupboards teared off from stud walls but he doesn't think that will happen, provide if the fittings are installed properly. Could anyone advise if this is a good idea, or should I stick to plywood for peace of mind?
Would appreciate any thoughts here.
Thanks, Heather
Thanks, Heather
