kitchen floor moisture & tiling
14 Aug 2008
Bedfordshire
I had my kitchen replaced about 18 months ago & the floor replaced with a new concrete one. House is Victorian so the previous floor had no insulation or damp proofing.
I was going to fit Karndean or similar vinyl flooring however the concrete is still a bit damp.
Builder suspects there is a problem with dpc on internal walls and moisture seeping into floor.
I'm wondering if I could use tiles on the floor instead on the basis that they and the grout are more porous than a vinyl floor and any slight moisture would not cause a problem and/or escape.
Thoughts and advice on this?
nope...
has the floor got a dpm?..
is it coming down/from the walls?
has the walls got a dpc level?
that new concrtete floor with dpm should be dry by now.
New floor has a dpm however the thought from my builder is that the damp might be coming from the walls. The external walls have a dpc but no idea with internal ones.
Yes the new floor should be dry by now....
