Hi everyone,hope you can help. My hot water in the kitchen mixer tap takes an age to come through. The rest of the taps in the house are fine and don't take long at all.
We run on a oil fired combi boiler and the flow to all the taps including the kitchen sink is very good. When the water does get through it is fine, just takes a long time to come through the pipes.
Other info: there are two isolation taps under the sink in the cupboard which turn off the water supply to the rest of the house. One for the hot water, one for the cold.
It also seems to come through quicker if on full, sometimes the hot doesn't come through at all if the tap is only slightly on.
Hope this makes sense and someone can help. Seems daft to call a plumber out to look at a tap that works fine. (All be it a little tardy)
Thanks, dugald
Thanks, dugald
