Kitchen is half concrete/wood - Can I use Self Level?
20 Nov 2010
Manchester
Hello guys,
Firstly, Merry Xmas! Hope you had a gooden.
As the title implies, we have ripped out the vinyl in the Kitchen to reveal a half concrete, half wooden floor (wooden floorboards). There is a dip/drop/rise where they both meet (approx. 0.5cm).
We were thinking of tiling and have been advised to level the floor.
A builder mentioned that I could get a thin sheet of plywood and nail it to the floorboards, which would eliminate the 0.5cm gap. After that we could use self level.
After Googling, I have learned that wood floors constantly expand and contract, the self leveling concrete would detach and shale within days. Tje next thing I researched was backer board but apparently even backer board will not hold the self leveling stuff, for it will be too thin.
So my question is, how do I level the floor?
If you'd like pictures of the floor, please let me know.
Thank you and Merry Xmas again! [/b]
I had the same situation with floor substrates. My tiler braced the floor joists, replaced the floorboards with ply, then poured leveling compound over the whole lot. It's been down for a couple of months and seems to be holding up ok, though I do find the hollow echo when I walk on the old wooden side a bit disconcerting.
ok you have to differant substrates,so you will have to treat them differantely...as you have said..movement this is the key thing to a certain tile failure...
timber....
lift your floorboards check joist spans etc...
then seal underside and edges of wbp ply with sbr, (22mm/25mm and lay to same level as concrtete,leave a 5-10mm gap between them.
conctrete floor sweep/clean and apply a sbr or acrylic primer to this...(helps adhesion of addy and stops dust from interfereing with addy also)
tile fixing
you will NEED a exspansion/movement joint placed between the subtrates and follow up through your tiles..some come in colours to match your grout..
movement joints from...
shutler
gradus
genesis
dont forget a quality flexiable cement based adhesive/grout...
what type of tiles/size are you fixing?
