Hi All,
I'm installing a ceiling mounted Island Extractor which comes with a 3pin plug. Just thinking about the best way to wire it up.
What I dont want to do is just connect it to a socket as...
1. the only socket it would reach would be one in the bedroom above
2. a socket added to the circuit next to the extractor in the ceiling void wouldnt exactly be easy to access.
So, I'm thinking that I should:
a. Install a labelled fused isolator DP switch in the kitchen - Next to the C.U. at eye level. (Avoids having to do any chasing etc).
b. Run 2C+E cable (1.5mm) from the isolator up into the ceiling void and connect to the terminals in the back of the fan housing.
Seems a sensible way of being able to turn the unit off/on for maintenance, cleaning etc.
Any thoughts?
Any thoughts?
