Kitchen lighting
2 Jan 2009
Lanarkshire
Looking for a quick opinion from everyone as to what lighting would be best for my kitchen in my new flat. Currently we have something like this but it looks a bit old and scabby, plus uses R80 halogen spots.
The kitchen is about 3.5m long with a window at one end and door at the other by 2m wide. There are wall cabinets along both long walls.
I am limited by the following - concrete ceiling, so no PL downlighters. Single steel conduit box in ceiling as only mounting point. No chasing practical so no pelmet/under cabinet lights.
What do we all think then? HF florescent fitting? Something else?
Colin C
Blimey - that photo is of a light taking MR16 lamps - one with R080s must be enormous... :eek:
Is there no way that you could lower the ceiling enough to get cables to the edges? Plasterboard on thin battens would do. You'd then be able to have lights on top and below the cabinets.
Failing that, start looking at the major office/retail/architectural lighting manufacturers.
Fluorescent tube lighting doesn't have to look like this:
For example the top right one here:
or these:
And these are all from one maker.
Plus you could also try badgering Osram to see if they've finally got around to making off-the-shelf products using Planon lamp technology.
