Hello
I had a new kitchen fitted 6 months ago. At the same time, the old ceiling light fitting was replaced by a new fitting consisting of four spot lamps. We also had three new striplights fitted under the wall units.
Everything had worked without a problem until tonight. Now, when I switch on the striplights they all light up for a split second and then go off. However, the MCB and RCD don't trip. This process repeats everytime I switch them off and then on again. The ceiling lights still work without any apparent problem.
The wiring is as shows in the attached diagram. The switch wire is three core 1.5mm.
What I've also noticed is that one or two of the bulbs in the ceiling spot lights don't seem last long.
Ceiling spot lights 4 x 40W (although only two have been working recently as the other bulbs have blown). The striplights are 24W each so 72W in total.
Does anyone have any ideas?
Mike
Mike
