new flat=new headaches
tap astracast mixer
hot water gravity fed (1 storey flat)
hot to bath 22mm flow ok
hot to basin 22mm red. to 15mm approx 1.5 ms. flow ok
HOWEVER!!??
hot to sink 22mm red. to 15mm approx 3 ms. flow rate crap (about 3 litres per min.)
self tapping wash mac tap... ahaa!!! methinks cut out disc is blocking port(s) on hot side of mixer!!
strippped down tap completely
wire mesh not blocked
ports not blocked
broddled some 13 amp fuse wire into tap body no blockage
took off mixer blew threw it no blockage
dismantled from sink.. check tails (15mm to 8mm) no blockage
using the flex connecting 15mm copper to tap tail..ran off a full 10l bucket from the hose in a minute
reassembled and managed ... once again to get about 3 litres... a pitiful trickle.
Totally befuddled.
only thing i can think is previous owner put on a dedicated high pressure tap by mistake and just put up with it. But although ive seen lp and hp bath fillers never seen a kitchen sink option of hp/lp.
tap astracast mixer
HOWEVER!!??
ports not blocked
Totally befuddled.
