The hot water pressure on the hot water of our kitchen mixer tap has recently gone to virtually zero. Cold is fine. I have removed the tap head & cover & found that if I loosen the hexagonal nut slightly, replace the cover & tap head, all is fine. I am worried though that by loosening the hexagonal nut, I may be inviting trouble (leaks?). Does the mechanism need replacing or the washer replacing or what? Any advice welcome.
