I need to change my tap and the copper pipes are welded. I have turned water off at the mains (hot and cold) and run taps (upstairs and down) to empty pipes. The hot water still seems to be running slightly in the kitchen (the taps upstairs have run dry). I don't understand why this is happening.
Also, would it just be easier to cut pipes as mentioned in other peoples queries, and use a flexie hose or are these just for ordinary taps and not mixers?
I have tried to heat the pipes to disconect them but it doesn't seem to be happening.
Could i use push on thingies to connect new taps after cutting old ones off?
