Got a problem with my kitchen mixer tap in that the lever can become very stiff, when lifting it up and down. This can go on for weeks then resolve itself before becoming stiff again. Any ideas?
I have an idea that you have a kitchen mixer tap, and if you have a single lever then I guess it's a monobloc, but otherise it's of unknown brand, model, age, and finish. Oh, and I believe that you have hot water, but have no idea whether it's mains or tank fed.
You mean you can't give me an answer with the info I've provided? Ok, can't give you the make or model but it is 3 years old and is a chrome finish. It is single lever and the hot water comes from a tank.
This could, as observed by doitall, be something worn or loose. I've had a similar problem with one similar monobloc, which was caused by the failure of something internal.
If the tap has any kind of decent warranty (like the one in BNFNQ does), then I'd go down the route of asking the manufacturer. In my experience the manufs are happy to send out new valve headwork on the condition that you return the old one so that they can analyse what went wrong.
Before you do that, however, why not take off the cover and see if anything is loose enough to be fouling the arm over the course of its travel?
