- Joined
- 6 Sep 2004
- Messages
- 1,069
- Reaction score
- 71
- Country
A friend of mine has bought one of those kitchen mixers with a pull-out spray and has asked if I can install it. I took a cursory look at the instructions and have read the following.
It could be a criminal offence to use this tap with water supplied by a Water Company. (The supply pipe is the one which brings the waters supply into your home and is directly connected to the public water main).
This tap has an outlet on a flexible hose which, if left immersed in water could result in contaminated water being drawn back into the pipework if the supply pressure dropped. To prevent contamination of drinking water in the premises and in the water main, and to comply with the legal requirements of the UK plumbing regulations and byelaws (Water Regs 1999), both hot and cold water supplied to this tap must come from a storage cistern.
Has anyone fitted this sort of item before and if so did both the hot and cold supplies really have their own storage cisterns? I cannot envisage having seen any sort of setup like that previously. Would appreciate any comments.
