Hi guys,
I've had a new kitchen fitted at the same time as buying a brand new built in fridge freezer. The fridgefreezer is the type where the doors screw on the appliance door and don't require hinges (http://www.euronics.co.uk/refrigeration/fridge-freezers/blomberg-knm1551i-blomberg-bi-fridge-freezer/1097)
Looking at the photo here I was not happy AT ALL with the left hand side of the job (the right isn't much better) and the doors pivot forward too and aren't aligned.
The fitter has said "that's the best that could be done especially as the left hand side of the door would be binding onto the end panel if he hadn't hadn't used packer to push it away".
surely this is not the case for all built in fridgefreezers?!
Thanks for any help/advice you can give.
