Kitchen planning - space for fridge freezer
10 Dec 2010
Surrey
Hi
I'm just in the process of fitting a kitchen.
Can anyone tell me how much space I should leave for a fridge freezer. Most seem to be about 600mm, although some sites say you need to leave space around the appliance. However everywhere I look says different measurements. Some say for a 600mm fridge freezer you should leave a 600mm gap, others say 650mm and some say 700mm.
My fridge freezer will be going between a wall and a run of units so I'm just trying to work out where I should start the units from.
Many thanks all.
heeelllooo and welcome pidge026 :D :D :D
you need to read the manufacturers instructions to see what space you require
if you set the space then your stuck with whatever fits or less clearance than recommended
