Looking to replace the kitchen - the new one will be a slightly different size.
1) What do you do if the standard kitchen cabinet sizes you want do not fill an entire run? How do you fill the gap? One way I can think of is to have a freestanding cooker
2) If I want a hob and built under oven I understand that my worktop will need to be of a certain thickness - should the hob be sticking out from under the worktop? some of the hobs are quite think 5cm+ - obviously most worktops are not.
so in that case woudl the oven not fit under properly?
3) I want some full height units and want to put a fridge in one and a freezer in anothr next to it. i believe i need to get some handles that will fit on the door specific to my design but can i choose how high up the cupboard the fridge/freezer goes or aret hey usually set? and then you need to find to something to go with the sapce above and below
4) i suppose you just put the frize and freezer into the unit - but where do they ventilate - in the space behind?
hope that makes sense
if anyone knows a good guide for all this please let me know!
