The drain pipe under my sink has been knocked off it looks like some sort of adhesive was used to fix it in place. Can any one let me know what's the best way to re-attach the pipe to my metal sink?
That's plumbers mait you can see on the gasket. It wouldn't have been stuck but clamped from the plughole above, usually the centre ring which the plug spindle goes through tightens it up. However, it looks like yours has broken off so it may have been over-tightened or there is too much tension on the waste pipe in its final position. You'll have to replace the pop up waste assembly as the gasket needs to be compressed to form a water tight seal.
gluing the gasket to the waste and sink will probably be a mess and fail due to the weight of the assembly and trap.
I think I will try the CT1. If it doesn't work I'll get someone out, it sounds a bit to complicated for me to replace the waste assembly gasket. The plug hasn't worked since I moved in so I'm not worried about getting that fixed at the moment.
