Kitchen-sink: space needed for plumbing?
2 Mar 2015
Devon
How much space is needed for plumbing under a kitchen sink?
I ask because I have a space 143cm wide - and want to cram in three things: the sink, a fridge and a dishwasher.
Would it be possible to get extra cupboard space by mounting the sink on the work-surface itself, rather than in a recess?
Hope this makes some sense!
Crawf
I must be misreading something here, I can't quite visualize a sink on top of a work surface. My bad?
Bear in mind, the dishwasher will be sharing the water supply and drainage with the sink. All you can aim to do is run all services as close to the wall as possible, leaving you maximum cupboard space.
The fridge, requiring no plumbing connection, can be sited anywhere - but rear ventilation will be required for heat loss purposes - is there anywhere else this can go to save pressure on sink space?
Sorry if I have misunderstood your needs - others may be able to chip in with more useful advice.
A lot depends on the bowl of the sink, which vary widely (and on whether you mean a full size or a narrow dishwasher).
If you have a 45cm dishwasher and a 60cm standard fridge, you need 105cm clear below the worktop level, which means a 38cm bowl maximum. You can get separate plumbed in draining boards if you just need a spill catcher below a tap.
Possibly look at getting a 143cm wide worktop fabricated in steel including the sink and drainer, similar to
http://www.stainlesssteelworktopsuk.co.uk/Mini+Kitchens+For+Compact+Spaces/0_CAAA140.htm
you could go for a half height dishwasher and install under the sink
A half-height dishwasher? As in the mini-counter-top sort? Or is there something else out there?!
