been to a kitchen sink today that wont drain,the trap is clear and i stuck my metal snake 5 metres down the pipe and its clear,i only have to turn the tap on for 5 seconds and it wont drain any ideas
If you fill a metre length 40mm pipe with water and note how much that it holds (out of a litre) you should then be able to work out exactly where your blockage lies by tipping a known quantity down the sink from a measuring jug.
exactly it dont make sense as i would pressume that if i can pour water down it freely when its not connected to the sink then theres no blockage but as soon as i connect it and run the tap for 3-5 sec it wont drain
