We are moving the kitchen from the back of our house to the front.
There is a storm drain right outside the front window where the exit pipes for the kitchen sink/dishwasher and washing machine will be (two in total).
We have been advised by Building Control that we are fine to use the storm drain as a waste drain - it's a combined system apparently.
So ... at the moment I have two pipes leading towards a flush to the ground grate.
Any advice on finishing this? So far I've thought:
1 Building up around the drain (probably with bricks) to fit a grate and then fitting the two pipes through this to prevent splashing around.
2 However, this also still needs to function as a storm drain for rainwater so I'm thinking of drilling some holes through the bottom level of bricks for rainwater to seep through.
Thoughts, opinions welcome!
