Kitchen sink waste pipe
12 Sep 2015
Trying to connect a waste pipe to replace previous leaking mess.
I installed a fairly straightforward set for 1.5 sink but after the u-bend used some creativity to connect it back round to existing pipework.
Will the loop cause problems?
Time will tell, there's a bit of a strained bend on the right.....
In retrospective, McAlpine do some excellent waste kits, or maybe two telescopic bottle traps facing each other, connected together with straight pipe with a swept tee in the middle.
If it does block there's enough items to undo!
John :)
You need to take the shelf out and you've got the trap connected to the T wrong - use the other end of the trap onto the T and everything will drop down lower- that bend @ the top of the trap wants to go on the J of the trap at the bottom
