Yesterday one side of the kitchen mixer tap stopped working - I could turn the tap lever but it wasn't engaging with the base and the lever came away freely from the base. I can turn the tap on and off but only by pressing the lever very hard into the base as I turn. I'm worried this will cause further damage over time.
Both the tap lever and the base have milled edges which are supposed to engage to make the tap turn. There is also a small hole (screw?) which faces downwards when the lever is vertical in the off position.
Is there any cleaning etc I can do or will I need to buy new parts/get a plumber in?
Thanks in advance!
Thanks in advance!
