Hi, my kitchen sink tap is leaking and I would like to replace it. I bought it from Ikea 10 years ago and cannot remember if the sink already had a hole or not. If it had, I assume it can be matched with most taps. But what if the hole was drilled in the sink for the tab I got? If it was, did it have to match the specific size of the tap? It has a 19 cm circumference, bigger than usual. My query now is: how can I find out if the hole is of a standard size? Not easy to see from the bottom. And very importantly I don't want to remove the leaking tap until I have bought the right new one.
Thank you so much.
Thank you so much.
