kitchen tap leak
30 May 2006
Nottingham
I have a monobloc kitchen tap which has been leaking. I removed the stem which holds the washer. The washer has been shredded. I put my finger into the chamber/tap body and felt the seat (which the washer touches when turning the tap off) it has a bit missing. So everytime i turn off/on the tap the washer cuts into this jaggered seat and eventually shreds a bit which in turn causes the tap to leak.
Have put a new washer as a temporary fix. Don't fancy changing the whole unit because access is poor. I have heard there is something called a 'poppet' (think that is the correct spelling) which you can screw into the tap body. It provides a new seat for the washer. Has someone heard of this and if so where can i get hold of one and what is it's correct name.
thanks for the reply
have already tried the reseating tool. it is ideal for if the seat is pitted due to rust etc. my seat has a bit missing. i was hoping to find something like an adaptor/spacer which you screw into the tap body and then screw the stem into the adaptor/spacer. hope it makes sense.
if the seat`s got a bit mising lika cut...then it`s buggured :cry: you may find an insert/jumper kit @ a shed but they aint a mucher
looks like it is what i am looking for, an insert/jumper kit. what do you mean by shed? would be grateful if you can put a link etc
