Hi there, I've recently installed a franke sink & pilatus tap which has a spray attachment. The problem I have is that the hot water supply (which is gravity fed) doesn't have sufficient pressure.
From what I can gather I need to install a booster pump to rectify the situation. What I would like from this forum is a bit of advice over which pump to use. I'm sure I've seen a central heating pump used once before and would be interested in any comments/instructions that you may have.
Thanks in advance
Thanks in advance
