Hi i am due to replace the kitchen sink and tap I have at the moment.
I can cut the pipes and replace with the flexitails but the nut that secures the tap has been placed directly above a support that runs under the sink and i presume supports the cabinet, So there is only about a 1cm gap between the bottom of the nut and the board that runs all the way under the cabinet. So this stops me getting a tap spanner on the nut any ideas of anything else i can do. When i replace the sink I dont want to remove the sink if there is a problem with the tap in the future help please ???
Couldn't make this up if you tried
