Kitchen Unit
5 Feb 2004
I need to remove the base section from one of the kitchen units so has to fit a dishwasher I found under the cupboard base unit two screw fastners the type you get that comes with diy packs I have turned the two screws but I can not pull out the base bottom any help
Have you removed the bottom plinth and also check the fitting screws under the worktop etc.It can be difficult sometime it can be air tight,might be best to run a saw thru' the middle and break it up.
Thanks for the reply have pulled away the bottom plinth and can now see what has to be done :cool:
