I am having a new kitchen fitted and have received some conflicting views from a couple of electricians so I was wondering if you helpful chaps could confirm a couple of things for me.
1. I am switching out a slot-in double-oven/ceramic hob electric cooker for a separate 1 1/2 oven and hob. The oven is rated at 5.5KW and the hob at 6.5KW. I currently have a cooker circuit run in 6mm cable and protected by a 40A MCB. The first electrician simply said that I couldn't connect the hob and the oven to the single circuit due to the rating of the appliances. I thought that applying diversity makes this fine and, as the circuit is protected by a suitable MCB, means that the MCB would trip before the cable burst into flames in the case of an overload? I can understand that the ideal solution is a second circuit but this electrician was making out that it had to be done to satisfy the regulations.
2. The first electrician took one look at my consumer unit and said "No RCD protection, you'll need a new one". Is this strictly true? I use an RCD adapter when I plug in my garden tools and the garage has RCD sockets. Alternatively couldn't I fit RCBOs to the two ring main circuits (if I can find any that fit my CU)?
The second electrician basically stated that what the first guy had told me was not true in terms of the regulations. He then quoted me a tenth of the price for the work that I had originally requested (moving a socket so that it isn't behind my new fridgefreezer location and moving the CCU).
Apologies if these seem dumb questions but I am always concerned when two registered tradesmen tell me completely different things.
Thanks in advance.
Thanks in advance.
