Hello Guys,
I've been oversees for a while and just catching up on the new regs and recently looked at a friends kitchen which was installed about 2-years ago.
He only has socket outlets above the workbench and all socket for appliances are under the bench in the cupboards with no immediate means of isolation. Even the socket for the oven (and gas Hob with power cord) is under the bench in a cupboard. Given that a plug and socket are not deemed as a form of isolation in an emergency can I assume that (at least) the oven part of the install is against the regs? Is it no longer the practise to install a switch spur above the bench to control sockets below/above (cooker hood) the bench?
Also, to get the appliance cords into the cupboards he has cut off the manufactures plug-tops,,, pass the cord(s) thru a small hole drilled in the back of the unit,,, and then fitted his own plug-tops. Is this normal?
And finally, I read somewhere that if there is at least one fixed lug on a flush metal back-box that we no longer have to earth the back of the box,, can someone confirm that this is the case?
Thanks in advance
Thanks in advance
