Hi - having just read a post on this subject, I am both a little more enlightened and also more confused:
I am fitting a kitchen worktop (40mm thick chipboard with hard glossy plastic surface), and need to join two straight sections together. The joint will be about 300mm from one end (i.e. just a short filler piece is required) and it will be over a supporting base unit.
With the worktop there came three joining kits: one packet containing a tube of 'colourfil' adhesive plus a bottle of solvent, and two packs containing some kind of glue/sealant with 3 'biscuits' and 3 clamp/bolts.
From the other post, I'm guessing the last two kits are for actually inserting a bolt/clamp into a channel made (using a router?) in both pieces of worktop so they can be tightened together after, I guess, inserting the biscuits and applying the adhesive/sealant?
The other kit with the colourfill stuff is, presumably, for applying to the joint at some point.
However, I'd rather find a method that doesn't require me using a router and biscuit-jointer, or these long bolts, and instead would allow me to simply glue the two pieces together and support them, say, with a couple of flat metal brackets screwed to the undersides. But would this work?
And what about the plastic filler strip that I've seen used elsewhere? I didn't notice any with the kit.
I'd like to produce a professional result, but is it possible without all those specialised tools? Any help much appreciated as I need to get going with this, er, tomorrow!
