I'm looking to refresh my existing kitchen oiled wood worktops.
At present, they're 'textured' i.e if you run your hand over them, you can lightly feel the woodgrain. I'd like to get them so that once they've been fully reoiled, they're smooth to the touch.
I've read conflicting advice as to the sanding grade recommended. Some sources talk about starting at 120 as the initial finish and then going up to much higher. Others say that once you go over 180, the surface becomes too fine for the oil to penetrate properly.
My plan was to sand down initially with an orbital sander at 120 and then do final tidying by hand if essential. With that in mind, can anyone help advise to what grade I should use for both the orbital and hand please?
