Hi from a plumbing noob. First post too, so please bear with me...
I've got two questions...
First Question: Klunk, klunk, klunk...
I recently moved into my first house. Seems to be in good order, but noises from the water/heating system are driving me crazy. The master bedroom is located partially above the kitchen where the boiler (Potterton Netaheat) resides. The water cylinder is located in a cupboard adjacent to the master bedroom, but on the opposite side of the room to the boiler. I presume the water flows from the boiler under the bedroom floor to the cylinder, but I could be wrong. Every few minutes, I hear klunk, klunk, klunk from what sounds like the cylinder cupboard . I presume this occurs when hot water starts flowing through the pipes. Despite my efforts, I cannot seem to pinpoint the source of the noise. I've been advised to ensure that the pipes are secure and cushioned to prevent banging, but so far, I haven't found any pipes that aren't held in place by secure plastic fixings. When the boiler was serviced as part of my British Gas Homecare contract, I was told this is fairly common and normal. Surely there is something that can be done about it. Do you have any advice for me?
Second Question: Replacing a Switchmaster 805 timer
Once I recovered from the shock of my first gas bill (£368) , I decided I need to put my water and heating on a timer. The problem is that we've got a lousy and somewhat prehistoric Switchmaster 805 timer. While trying to figure out why the thing didn't work properly, I noticed that the device fits onto a backplate... Neat! I had hoped to find an electronic Switchmaster timer that would fit on the same backplate, but no luck. My question is, what electronic 7 day timer would you recommend as a replacement? I haven't messed with heating timers or heating systems before, so I'm looking for something that will be so easy to wire up (using the existing wires) that I could almost do it blindfolded. Any ideas?
If you've got this far - thanks for bearing with me... And thanks in advance for your assistance.
Regards,
Lunk
Regards,
Lunk
