[i
mg]
Apolgies - my 2nd queston today. Under pressure from 'Er Indoors to fix the heating for Xmas!
One of the radiators was cold, so I took the head off the TRV. This valve is an old Myson one, with grooves at the bottom and a metal ring that hold the plastic head onto the valve body.
When I put the pliers onto the pin to free it, it almost came right out. The rad is still cold. My three questons are;
1) As the pin came out by about an inch, is the valve knackered?
2) The valve is the angled type. If I fit a new TRV, are inlets and outlets to TRVs to the same dimensions (ie. will a new TRV of a different make bolt straight on), or will I need to alter the pipe to the valve?
3) If I buy another Myson TRV, is there more chance that it will bolt straight on wthout any alterations?
Merry Xmas to You All[/img]
