emailed two LABCs the following question
Hello,
please could you give me your scale of charges for notifiable electrical works carried out by a person not being a registered domestic installer in one of the part p competent persons schemes?
regards,
XXXX
ANSWER FROM LABC A
The Building Regulation fee relates to the cost of work and therefore schedule 3 of the attached fees document applies. Please note that the person installing should still be qualified to the appropriate City and Guilds standard to install and test even if they are signed up to Competent Persons Scheme
ANSWER FROM LABC B
Please find attached scale of charges for works carried out that require Building Regulations approval. The fees for electrical works carried out by a person not registered with one of the competent persons schemes are based on an estimated commercial cost of the work and can be found in schedule 3 of the attached document. These fees are currently being reviewed and may change in April 2007. In order to show compliance with the Building Regulations it is imperative that you contact the Local Authority to arrange a first fix inspection and that the appropriate BS 7671 installation certificate, signed by a qualified person, is supplied on completion of the work.
If you have any further queries please do not hesitate to contact me.
Comments anyone?
Hello,
regards,
XXXX
ANSWER FROM LABC A
ANSWER FROM LABC B
Comments anyone?
