Having recently cabled the house, I put in the necessary wiring (3 bits of coax to the living room) for a Sky+ install... in case I ever wanted it. I have a Labgear LDU608G distributor connected into a Labgear PSW351T. There's 2 LNB feeds and a UHF feed connected into the distributor.
However... I cannot receive any freeview on a TV connected into the PSW351T. Facts below:
- I have removed the PSW351T and installed a standard coax module, and then moved the downlink cable to a standard output... this works. I can receive freeview on the affected TV
- All the other TVs in the house connected to standard outputs on the distributor work fine
- The "Sat/UHF&CCTV" switch makes no difference to the PSW351T connected TV but setting it to "Sat" makes all other TVs in the house lose signal
- I have no idea of the quality/state of the dish/LNB. Is it a requirement that the LNB works for the PSW351T to do freeview?
