lack of drip guard under widow sill
10 Jan 2006
London
I dont know if its been painted over or was never there to start with (cant see any on the neighbouring sills).
Any tips on how to cut one?
Have seen drip moulds mentioned elsewhere on the site - what are they and how do you get hold of them - or can I make one?
Thanks in anticipation
Neil
your capillery or drip groove should be about 5mm deep 5mm wide 10mm back from the front edge
the only way to do it if you cant get a router in is to use a hand molding plane
a biscut joiner or some simmilar tool :D ;)
a temporary fix is to run a bead of silicon along to form a low point for the water to drip off
thanks big-all
small point I failed to mention is the sills are masonary.
might try the silicon in the meantime thou'
neilfitzgerald said:
thanks big-all
you would get a fine fireworks display though :LOL: :LOL: :LOL: ;)
maybe an angle grinder with a batton to cut against!!!!!!!!!! ;)
