I am not sure whether this is the right place in the forum to post this. If it isn't I hope that someone will tell me and then I can post it in the right place.
I need to install some network cable on the outside of my house. I need to bring the cable down from the top floor, (entry point is 26 foot above ground level), to the ground floor.
The problem is, I am doing this at the side of my house which is a passageway bounded by my side wall and the neighbours sidewall. The gap between the walls is 4 feet.
The rule of four would generally indicate that I need about 6' 6" for my ladder to have the safe 75°.
Is there any generally accepted workaround for this? Is it possible for instance to use eye bolts to fasten the ladder to my wall to make it safer, or is the only real alternative to have scaffolding erected, (which seems like a huge expense to fit one cable).
Any thoughts gentlemen? Thanks.
