Hello all.
I have a series of copper pipes (water supply + radiators) that are running quite close to each other.... close enough so that I can't quite put pipe lagging around them. So I am using foil backed insulation wrap for these pipes instead. I would like to wrap all the pipes together (not individually) but am not sure this is best thing to do.
However, my concern is condensation - the pipes are obviously carrying a mix of hot and cold water and I am worried that I will have a condesation issue from the cold pipes.... Is this a major problem? Should I wrap the cold pipes separately?
Any help and advice would be much appreciated.
