Laminate curved
19 Dec 2004
Hello, We would like to join two different laminate floors on a curve. Along that curve we would like to put some natural stone mosaic type of tiles. What is the best tool/ method to cut the laminate flooring curved and what is best to put in the joints where the laminate meets the pointing? What about the expansion gap? :?:
heeelllooo eludrago and welome
so if ive got this right what you want is the eqivilent of an arc cut on both edges and parted a bit say 100mm to put ceramic tiles in between now if this is the case things youve got to keep in mind the laminate floor is about 9mm thick how thick are your tiles your tiles must be mounted on at least 9mm ply to stop movement and cracking
give us an idea of the radi of the curve type of floaring click type ect thickness of tiles gap to fill ect and will try and help
