I have laid laminate boards on top of the original carpet which is on top of floorboards. The issue I have is that part of the floor is bouncing and squeaking. The question is, can I correct the problem by putting thin plywood under the affected area ?.
does the flooring dip when you stand on it!!!
or is it up in a hump before you stand on it!!!
a pinch point is usualy where theres no expansion room left where not enough space was allowed in the first place or its been blocked by no nails quadrent ect
