I am intending to replace the laminate floor in my hall. The current edging is 15mm scotia which looks pretty unpleasant when taking a 90 degree mitre around the 8 door frames.
Removing the skirting and undercutting 8 door frames (with the risk of damaging the skirting in the adjoining newly decorated rooms) is a non starter.
Because the hall is only 1350mm wide i think I can cut the expansion gap to about 3 mm thus allowing a narrower bead.
I was thinking of using a 9mm X 12mm D section quadrant in the hope that it will look better around the door architrave.
I am hoping that you guys can offer some advice as to how you have dealt with this problem.
All advice welcome
All advice welcome
