I've recently laid the TileLoc tile effect laminate (from B&Q) and am very pleased with it. However, I have damaged the edge of one and, because I had difficulty installing it, decided that I could get some sort of clear epoxy or varnish to repair it at a later date. The area is only about 10mm long and isn't visible at all.
What should I use and where do I get it from? I'm scared of using something and it reacting with the laminate making the damaged part obvious.
