Laminate Floor
1 Sep 2002
Has anyone any ideas how I can lay quadrant around the rounded bottom step of my stairs, please.
Cut the quadrant slightly over lenght first and then soak it in the bath for a while until it starts to curl. If it is the veneer faced quad you may have to be careful the veneer doesn't start to peel but once it is flexible enough to bend without snapping recheck the length because it may have changed , fit in in place with glue and you will probably have to pin it as well but just sink the nail heads with a punch and get some sealant to match the floor colour.If that fails the other way is to do lots and lots of cuts to the back of the quad very close together at the part where it is to bend using a hacksaw and then carefully bend it to suit.Good luck.
