Laminate flooring underlay advice
7 Dec 2019
Hi All,
Planning to lay some laminate flooring on the ground floor of the house, concrete base and house is 5 years old.
Has anyone any advice about underlay with the aim of making it sound as solid as possible? Should I go for 2mm or 5mm expanded foam, or cork with a moisture proof layer added underneath?
Thanks,
M.R
Ive just laid some laminate flooring this week.
I used timbertech2 acoustic gold flooring - its expensive but the floor sounds really solid, Im pleased with it.
The underlay is seriously heavy -each roll weighs almost as much as a bag of cement.
https://www.tradepriced.co.uk/timbertech2_acoustic_gold_laminate_underlay.html
Delivery was good - 48hours and they sent a text with a 2 hour time slot.
foxhole - Trying to do anything to help deaden the sound or reduce the hollowness of it.
Dazlight and Notch7, thanks for the pointers. I'll have a look at those.
I did some more digging on the forum and found a few recommendations for Duralay too who seem to produce the Timbermate Excel. I see Screwfix locally stock their Premier Wood and Laminate flooring underlay.
https://www.screwfix.com/p/duralay-premier-wood-laminate-flooring-underlay-3mm-10m/48485
Layed on concrete there is no hollowness, you only get that on a hollow floor, like timber.
Got my hands and used some Timbermate Excel in the end, £4 sq m.
Pleased with the result!
