is it ok to use a coloured gap filler around the door frames etc for laminate flooring or is this a no no because of the expansion needed, I want to cut the bottoms of the frames and alcatrave to slide it under but because im using the easy fit click laminate im not going to be able to get it to click together and slide it under the frame.
Last thing does the scotia beading need to be pinned to the skirting or can it just be glued to the skirting with no nails?
thanks
thanks
