I'm looking to fit laminate flooring in an upstairs room with a concrete floor. I've never fitted laminate before but I'm a competent DIYer. I do however have a few questions to make sure I'm doing the best possible job!
1) Do I need a damp proof membrane? I understand this is recommended for new or refurbished premises with concrete floors, is it required on a floor which has been in place for 25 years? If so, is an underlay with integrated DPM recommended or separate?
2) The floor is relatively level (i.e. not bad enough to justify levelling) but in places it is slightly off i.e. it might drop by 2-3mm over a couple of feet in places. I also want the sound insulation to be as good as possible. I was thinking of fitting 5-6mm fibreboard underlay as I understand this will "bed in" over time to take out minor imperfections and is relatively good at sound insulation. Is this the most suitable stuff to use or something else?
3) I'm looking at bevelled wood effect plank laminate. What's the best technique for fitting this to get the best (most genuine) appearance? A lot of laminate fitting instructions state to use the offcut from the last row to start the next row (so long as it overlaps by enough - how much is enough?). Is this to reduce waste or is it to give randomised overlaps? Is this the best approach or would I be best staggering by a fixed amount? 1/2 board? 1/3 board?
4) I'll be fitting scotia rather than replacing my skirting boards, as I have plumbing in places which means replacing the skirting isn't feasible. Where a wall is longer than a single length, is it best joining this like coving, i.e. cut a 45 degree angle on both lengths rather than butting up the two ends? What's the best way of finishing the scotia off where it needs to stop for doorways etc?
I think that's all for now thanks in advance for any advice!
