The laminate I laid in our 3 x 6m kitchen is worn out long since and she wants to replace it with soft step/ Cushion floor type vinyl. When I laid the laminate originally, rather than lift the skirtings, I used quadrant pinned to the skirting to allow for the expansion/contraction of the laminate.
At the door end of the kitchen, there was a slight 'hillock' - where a wall was once positioned and removed, extending the kitchen area a little. I took the opportunity before laying the laminate, of smoothing off the worst of the concrete 'hillock' and the laminate and underlay successfully managed to hide it.
My plan is to leave the laminate down and add the vinyl over the top, it's quite smooth, no splits or holes, just a worn face pattern. I plan to remove the skirtings and put them back over the top of laminate and vinyl, then sand and repaint. Under cutting the architraves with a multi-tool.
Anything wrong with my plan? Does the vinyl need to be fixed in some way?
