Laminated mdf
7 Nov 2003
I have recentley put together a Kithchen and have made up an island by screwing a few floor cabinets together. I need to get an end panel to cover up the sides of these two joined cabinets. I need a panel approx. 1.0m x 1.2m. Is it possible to get hold of pre-laminated mdf panels or can I stick the laminate on myslef? Not sure if \\\'laminate\\\' is the right word but I am referring to the white covering on Kitchen cabinet carcuses.
I think the white covering board you're referring to is Continental board which I've only seen the maximum width 600mm.
Can you not get extra spare kitchen door,like 2 x 600mm standard base unit door & that would give you 1.2m and join it together to match your kitchen unit
or Vinyl Roll stick-on
or Wickes do a 'Wall Panel kit' code no:120-390
