Lamintae flooring in bathroom
3 Aug 2005
Lancashire
I want to lay tile effect laminate in my bathroom, how do i go about waterproofing the expansion gap around the edge? I thought about putting a bead of bathroom sealant, thick enough so as it doesnt fal into the gap, all the way around the floor.
Also if i remove the toilet and refit on the top of the flooring is this ok so long as i drill wide enough holes in the laminate when i screw the toilet back down?
Any advise greatfuly received.
Rob
It will look crap. Buy some vinyl. Loads better. Water proof with no expansion problems and will look better than laminate.
That is what I did , put mastic around the edge and screwed the toilet thugh it and it looks better than vinyl ever could .
At the risk of sounding a bit daft, is mastic the same as sanitary silicone sealant?
If you really want to put laminate down then don't skimp on finishing the edges. Yeh, you could give it a bead of silicon sealant ('mastic') but if you do, use clear (translucent) not white. Anything bigger than, say a 4 or 5mm bead of silicon will look cheap & nasty. Laminate floor means using edging strips unless you can get the skirtings off. They're self-adhesive and will look better than a silicon bodge. Mattysupra is right, vinyl give a more 'professional' look. Always lift the bog (& any pedestal of a basin) and go underneath - it'll look better than cut edges.
you should avoid laminate in bathrooms and kitchens
unless there is absolutly minimal water spilled and it is wiped up within a few mins
in other words if you have kids who are messy [or bad aimers]
you are forever clearing up spills and splashes or look forward to replacing the floor within 2 or 3 years :rolleyes:
