Hi, I am going to fit some new stairs and was wondering how to interpret the rules on landings for stairs next to doors. K 1.18 Diagram 7 (Draft 2013 Edition)
I have spoken to building control and as I am not really changing the stair location there shouldn't be a problem however the rules are a little ambiguous in this example.
My front door is runs parallel to the bottom rung of the stairs 1000mm away, it opens inwards however the door is offset with the door opening away from stairs. This means that the arc of the door does not pass within the 400mm area.
I have added a picture as it is very hard to explain.
As the door does not encroach into the shaded area do you think this complies with the regs? [/img]
