- Joined
- 25 Sep 2004
- Messages
- 82
- Reaction score
- 0
- Country
This is my first post so I hope someone can help.
My brother has had a go at replacing the light switch in his hall and made the fatal mistake of not marking where the original wires went.
So now the hall/landing lighting doesn't work properly; can someone tell me what goes where.......this is what I found:
In the hall is a box with two switches as per the usual arrangement (one should turn the hall light on/off, the other should turn the landing light on/off). The box has six holes that accept wires, top left is COM, top right is COM, bottom left is L1 & L2, bottom right is L1 & L2.
A grey cable inside is wired thus: N to top left COM, L to top right COM, E to a securing screw against the metal backplate (although this had actually worked loose and was disconnected which would explain my brother's complaint that the lights were "doing their own thing"!!!
A second grey cable inside is wired thus: N to top left COM, L to bottom left L1.
Then there is also a single live cable that seems to loop between bottom left L1 and bottom right L2.
Any advice appreciated about what I ned to do......thanks in advance.
